1993 Ford Taurus surging ans stalling
12,000 MILES • 6 CYL • 2WD • AUTOMATIC
TTRAVELER
when i first start the car and until it warms up it surges up and down extremely. after it warms up it's stable but when you put it in drive the RPM's increase. in the book i have it say's that it's a vacuum leak. i looked for leaks and found one and fixed it at still does it but it does run a little bit better. any other suggestions.
thanks
Ray
Aug 8, 2009 at 10:18 AM
JGAROFALO
  • 489 POSTS
[quote:fdb62ac1de="ttraveler"]Engine Performance problem
1993 Ford Taurus 6 cyl Two Wheel Drive Automatic 120,00 miles
thanks
Ray[/quote:fdb62ac1de]
The EGR valve is another suspect. A bit of carbon deposit can hold the valve open enough to cause surging and erratic idle.
The PCV valve is another possible trouble spot. This should be replaced periodically.
Another overlooked point of trouble is the vacuum line to the evaporative emmision system. Take a look at the hose going to the lower left portion of the radiator support.
Just a few ideas of places to look for potential problems.
Aug 9, 2009 at 2:22 AM
