1993 Ford Taurus Please Help!!
LINDSAYMOLINE2010
Engine Mechanical problem
1993 Ford Taurus 6 cyl Front Wheel Drive Automatic 150tho miles
My 93 ford tuarus likes to sputter when I rev up the engine or I am stopped and it dosent want to take off. I have been told It is the cadiliac converter and there is broken fiber glass on the inside of it blocking back pressure from releasing. My car starts to smoke, I have been told it smoke because the back pressure trys to escape through the engine, Is this common in ford taurus?? what is the best way to treat it, and do you think this is the problem?
Jul 31, 2010 at 7:40 AM
  • 110,248 POSTS
This is a problem with all cars. And it cause other problems if it is plugged. One is a loss of power, misfire, and it can cause internal engine damage. If you look at the converter, when the engine is hot, see if it is glowing red hot. If it is, replace the converter. Also, if it is plugged, replace it. Otherwise you will end up with other problems.
Jul 31, 2010 at 1:35 PM
