1993 Ford Taurus Permanent Fan
PAULWOODLAND
Engine Cooling problem
1993 Ford Taurus 6 cyl Automatic 156000 miles
My engine cooling fan seems to be permanently on. I believe this kills my battery and is why my car will not start. I boost it and it works fine but when I shut my car off the fan stays on, killing my battery again causing my car to not start the next time I need it to. What should I do about this?
Feb 2, 2009 at 5:38 PM
  • 75,988 POSTS
Test the fan relays
Feb 2, 2009 at 9:40 PM
PAULWOODLAND
Thanks for the quick reply however I did some searching around last night and I found an answer on another web site. Apparently I had a switch left of my steering wheel. It had no label just a metal skinny knob which could flick up or down. I must have bumped it not knowing but I think that was the problem. I plugged in my battery charger and hooked it up to my battery and the fan came on immediately, so I flicked that switch down and the fan turned off. Hope this may help others with a similar problem. Not sure if the switch came with the car or if it was aftermarket, I didn't have a manual as I bought it used.
Feb 3, 2009 at 5:11 AM
  • 75,988 POSTS
It don't come with that switch it was rigged up so the fan can constantly be on. Just don't forget the switch when you shutdown.
Feb 3, 2009 at 6:45 AM
