1993 Ford Taurus No Start.
200,000 MILES • 6 CYL • FWD • AUTOMATIC
ANTONIO1
Hi. I have a 1993 Ford Taurus SHO 3.2. I have a no start condition. I have fuel pressure, spark but no injector pulse. The ignition module is 3 months old(OEM part). The ECM was checked and is OK. Could it be the crank sensor? Thanks for the help.
Feb 25, 2008 at 11:23 AM
MCLAUGHLINKSRIM
im having the same problem i have spark and a steady 40 lbs to the rail but no injector pulse i can crank it for ever and pull a plug and it will be dry ? i just replaced the fuel pump it started up fine ran for 30 min than died when i went to restart it would not fire i checked pressure to the fuel rail and as soon as pump stopped cycling the pressure would drop so i hard wired fuel pump that hold steady 40 lbs now but still have no spray or injector pulse any one know what that is?
Aug 5, 2012 at 8:59 PM
MCLAUGHLINKSRIM
mine is a 93 sho 3.2 as well
Aug 5, 2012 at 9:00 PM
