1993 Ford Taurus no overdrive
135,000 MILES • 6 CYL • FWD • AUTOMATIC
KINGJOHN1027
my wife usually drives the taurus SHO, but when i drove it on the highway the other day i noticed it wouldnt go into overdrive. it would stay in drive. shifts through all the other gears just fine. what might this me? a fuse or relay?
Jan 26, 2008 at 1:04 PM
TAURUSWHEEL
  • 718 POSTS
Have someone read the codes for you, or for about 30 bucks or so you can get yourself a obdI scan tool, easy to use.. a lot of trans codes will not turn on the check engine lamp. but will store a code in the continous memory. If the trans is not shifting when commanded to do so, most likely some sort of code is set.. could be a shift solenoid possibly, not sure.. there is also a way to read the codes by jumping terminals in the obdI connector in the engine compartment, you then read the blinking check engine lamp.
Jan 27, 2008 at 2:15 AM
