1993 Ford Taurus Motor will not shut off unless fuse remove
156,000 MILES • 6 CYL • FWD • AUTOMATIC
REGIS_67
I have a 93 Ford Taurus. The cooling fan have stopped working. Also when turning off the ignition the car will continue to run. To stop the car I can remove the 60 amp fuse that controls the cooling fans and the car will then shut off. I have replaced the ccrm and it continue to happen. The car starts and runs fine I just cannot shut it off at the ignition without removing the fuse? I can actually remove the key from the ignition while its running. The ignition has recently been replaced.
May 16, 2010 at 11:26 AM
  • 75,988 POSTS
Clean out the throttle plate could be sticking open and also misadjusted idle speed
May 16, 2010 at 5:33 PM
