I have a 93 Ford Taurus. The cooling fan have stopped working. Also when turning off the ignition the car will continue to run. To stop the car I can remove the 60 amp fuse that controls the cooling fans and the car will then shut off. I have replaced the ccrm and it continue to happen. The car starts and runs fine I just cannot shut it off at the ignition without removing the fuse? I can actually remove the key from the ignition while its running. The ignition has recently been replaced.
May 16, 2010 at 11:26 AM
