I have a 93 ford taurus SHO, I am having problems with rough idle and bucking at steady throttle but only at low RPM. Over 3000 seems to run fine.
I replaced the IAC, cleaned the MAF sensor.
I pulled the codes and it said "does not detect EGR valve opening". The EGR valve is pretty new without much carbon build up and i cleaned the EGR passage port in the intake, but symptoms remain. The codes also said weak # three cylinder, the wires have around 40,000 miles on them, Would a bad wire cause these symptoms?
Mar 17, 2009 at 7:14 AM
