1993 Ford Taurus IDLE
101,341 MILES • 6 CYL • 2WD • AUTOMATIC
HONG
The car is running good except that sometimes your foot is not on the gas and the vehicle is running at 25-35 mph.
Also have replaced shocks and now when you brake it make that squeeking noise.
Oct 1, 2008 at 2:30 PM
BMRFIXIT
  • 19,053 POSTS
Clean throttle body and replace idle control valve
check brakes and front end ball joint and tie rod end
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Oct 2, 2008 at 10:32 PM
