1993 Ford Taurus gets hot
KISSYKISSYKISSYMISSYME
Engine Cooling problem
1993 Ford Taurus 6 cyl Front Wheel Drive
I have a 1993 Ford Taurus Wagon-Everytime I drive it as long as I'm on the excellerator it stay pretty cool but as soon as I start to slow down the gauge starts to move towards Hot.When I turn the car off the gauge goes way up & the water boils out of the reservoir.Even thogh before I drive I make sur theres water & coolant in te reservoir to the line and make sure the radiator has water and coolant .I had a new thermostat put in a few months ago and it ran fine so I don't think it's that. Cpould it be the waterpump?
Feb 5, 2010 at 4:31 PM
BMRFIXIT
  • 19,053 POSTS
Check water pump if pushing coolant and circulating through the radiator
if coolant sealer was used may cause a blockage in the system
Feb 6, 2010 at 4:42 AM
