1993 Ford Taurus gas in the engine oil
LA GANZA
  • 44 POSTS
Engine Performance problem
1993 Ford Taurus 6 cyl Front Wheel Drive Automatic
why my sho is mixing gas with oil
Nov 14, 2008 at 2:55 PM
BLUELIGHTNIN6
  • 16,542 POSTS
The two most common reasons for this would be the fuel injectors or the fuel pressure regulator.
Is the vehicle smoking out the exhaust? If so, this could indicate that excessive cylinder wall or piston ring damage may have occured due to the oil being mixed with gas.
Nov 14, 2008 at 3:15 PM
