1993 Ford Taurus fuel
1993 FORD TAURUS
SAMUEL DUVALL
  • 38 POSTS
Engine Mechanical problem
1993 Ford Taurus 6 cyl Front Wheel Drive Automatic
This 1993 Ford Taurus 3.0 push rod motor won't start. Has 40lbs furl ptreasure at shraeder value and fuel pump runs all the time. Sometimes the pump will start to work then stops and engine starts. Have put 2 new fuel pumps on (JUST THE PUMP)
Oct 9, 2010 at 9:24 AM
Hi Samuel DuVall, Welcome to 2carpros and Ty for the donation
You need to have the CCRM ( Constant Control Relay Module ) tested this is where your problem is coming
Oct 9, 2010 at 10:16 AM
SAMUEL DUVALL
  • 38 POSTS
Good now what does it look like and where is it on the car??? I sure thank you and I am making another donation
Oct 9, 2010 at 10:33 AM
SAMUEL DUVALL
  • 38 POSTS
Did you receive my last question. Please answer ASAP PLEASE THANKS
Oct 9, 2010 at 11:30 AM
Sorry for the delay-it's located @-see below: Front radiator support
https://images.2carpros.com/forum/automotive_pictures/12900_c_37.jpg
The Integrated Control Relay Module or Constant Control Relay Module (CCRM) is located at the front of the engine compartment, on the upper radiator support.
Oct 9, 2010 at 8:11 PM
