1993 Ford Taurus Engine stalls then won't start
18,500 MILES • 6 CYL • FWD • MANUAL
BWILK
I have a 1993 Ford taurus SHO,185,000 miles.
recently I went to start engine and it started and ran for 10 sec then quit and wouldn't restart, it would crank. but not start. after some diognostics I determined that the Ignition control mod went bad so I replaced and car started ran good for week then I was driving and came up to a stop and engine quit and wouldn't restart. now sometimes it will start but run rough and sometime not start at all
Jul 14, 2009 at 5:35 AM
JGAROFALO
  • 489 POSTS
[quote:c107ff700b="bwilk"]Engine Performance problem
1993 Ford Taurus 6 cyl Front Wheel Drive Manual 185,00 miles
recently I went to start engine and it started and ran for 10 sec then quit and wouldn't restart, it would crank. but not start. after some diognostics I determined that the Ignition control mod went bad so I replaced and car started ran good for week then I was driving and came up to a stop and engine quit and wouldn't restart. now sometimes it will start but run rough and sometime not start at all[/quote:c107ff700b]
The prime suspect here is the cam position sensor. When this sensor fails, the computer does not know whether #1 is in the compression or exhaust stroke, so it takes a guess. There is a 50% chance that the engine will start.
Jul 14, 2009 at 10:04 AM
