this vehicle , while driving at 5 mph just quit. while coasting i drive i turned the key to start and the engine fired and started runing for about 2 seconds . I stopped and tried to start the engine but it acted as if the battery was weak. 10 MINUTES LATER i STARTED THE ENGINE AND IT RAN FINE FOR ANOTHER MILE OR SO. if i try to crank the engine it acts as if the battery is dead. I checked the battery ,it shows 11.62 volts. The engine doesn't evev turn over
Jan 25, 2010 at 5:14 AM
