1993 Ford Taurus DOESN'T START
FUGLY
Engine Mechanical problem
1993 Ford Taurus 6 cyl Front Wheel Drive Automatic
The ford taures doesnt start. the engine doesnt crank over. the starter has been checked and is good, new battery. There is power to the car, lights and everything works.
Jun 20, 2009 at 6:55 AM
BMRFIXIT
  • 19,053 POSTS
Does it click when trying to start ?
check neutral park switch
and alarm system if any
do you have power to the starter
check ground wire
let me know
Jun 20, 2009 at 9:48 AM
FUGLY
ground wire is connected right, no alarm system in the car. i dont know what you mean by check the neutral switch. has a brand new battery so there is power.
someone mentioned it is probably the ignition switch, i will most likely be checking that out today.
Jun 21, 2009 at 12:47 AM
BMRFIXIT
  • 19,053 POSTS
Neutral safety switch mounted on the tranny prevent engine from starting if not in park and or neutral check for power at the small wire at starter with key in start position
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_389.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic2_190.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic3_88.jpg
Jun 21, 2009 at 1:06 AM
NAPOLITAN_2000
you should check to see if the solenoid is rusty or the connections are bad. Its located under the hood on the drivers side that may need to be replaced. I had the same thing happen to me on two of my Tauruses/sables over the years; on a 1987 and 1991 model. Its located under the hood on the driver side before the strut tower
https://images.2carpros.com/forum/automotive_pictures/372869_solonoid_1.jpg
Jun 23, 2009 at 5:34 AM
