1993 Ford Taurus DISTRIBUTOR
KARL1755
Engine Mechanical problem
1993 Ford Taurus 6 cyl Front Wheel Drive Automatic
THE GEAR ON THE DISTRIBUTOR HAS SOME TEETH OFF OF IT. dO i NEED A GEAR PULLER TO GET THE GEAR OFF ? I DON'T WANT TO BUY A NEW DISTRIBUTOR CAUSE i DON'T KNOW IF THERE IS ANY DAMAGE TO THE CAMSHAFT.
Dec 21, 2008 at 9:05 AM
BMRFIXIT
  • 19,053 POSTS
Chances that the cam shaft is OK
yes you need to use a puller to remove the gear
Dec 21, 2008 at 12:46 PM
