1993 Ford Taurus crank sensor
19,300 MILES • 6 CYL • 2WD • MANUAL
KLADO
im looking at buying a 93 ford taurus sho it needs a crank sensor. How hard and expensive is it to replace? it also leaks oil from i believe the oil pan seal is this car worth buying?
Apr 29, 2009 at 1:48 AM
OBXAUTOMEDIC
  • 3,719 POSTS
[quote:64bed96b65="klado"]Electrical problem
1993 Ford Taurus 6 cyl Two Wheel Drive Manual 193,00 miles
im looking at buying a 93 ford taurus sho it needs a crank sensor. How hard and expensive is it to replace? it also leaks oil from i believe the oil pan seal is this car worth buying?[/quote:64bed96b65]
The crank Sensor is located on lower right rear of engine.
Let me know if you have a 3.0L or THE 3.2L and I will get you a diagram.
Apr 29, 2009 at 2:32 AM
