1993 Ford Taurus battery charge wouldn't hold
SATYA TATINI
Electrical problem
1993 Ford Taurus 6 cyl 170000 miles
Alternator is good, battery is comparivley new and a best kind. When the car is not starting, if I charge the battery and rimovethe charging equipment and start the car it starts ok. Now if I drive for a while and stop the engine, and try to start it, it will not start. It's possible I or some body I am working on my car incidentally shorted the battery that is +ve and -ve terminals joined long enough. Is it possible thata battery fuse exists on the car and it is blown
Sep 6, 2008 at 5:50 AM
  • 75,988 POSTS
You need to get both of them retested alternator might not be putting out and battery not taking the charge also cables/terminals clean and properly tightened
Sep 6, 2008 at 6:07 AM
