1993 Ford Taurus 6 cyl Front Wheel Drive Automatic
tranny went out, so I pulled it and had it rebuilt by a qualified mechanic, and then reinstalled. After reinstalling the car cuts out and bucks in park and every gear but reverse. Checked for codes and got several transmission codes. Investigated further and found someone had previously messed with the plug and had 2 wires crossed, one of which was a hot. Got the wiring schematic for both sides and now wires are in correct position, and all but 2 codes cleared and still have same problem. Replaced EEC module after following pinpoint test, only to have the transmission codes return, so I put old one back on and still have transmission codes, however these codes varied, but still have same condition. The bucking or serging doe not increase or decrease with engine rpm's or vehicle speed. This has become quite frustrating, time consuming and not to mention more money than I wanted to put into ths car, but now I am more or less at the point of no return. Does anyone know what might be the cause or what I should do next?
SPONSORED LINKS
Thursday, January 28th, 2010 AT 2:28 AM
