1993 Ford Taurus
4FATHER6
  • 1993 FORD TAURUS
Computer problem
1993 Ford Taurus 6 cyl Two Wheel Drive Automatic
I HAD TRANSMISSION REBUILT ON THE 1993 FORD TAURUS SHO AND FOR SOME REASON ITS NOT CHANGING OUT. IT STALLS GOING INTO 2ND GEAR. CAN YOU HELP ME OR GIVE ME YOUR OPINION ABOUT WHAT MAY BE HAPPENING. IT WAS ADVISED TO ME THAT IT MAYBE THE COMPUTER.
Monday, August 10th, 2009 AT 6:03 PM
BMRFIXIT
  • 19,053 POSTS
Did you run a code check
can you communicate with the PCM
Monday, August 10th, 2009 AT 8:06 PM
4FATHER6
No we did not run a code check how would we do that? And how do you communicate with the pcm? Would this problem affect the lights or anything else on the car?
Monday, August 10th, 2009 AT 8:17 PM
BMRFIXIT
  • 19,053 POSTS
Would suspect wiring issue and check for any corroded wires and or connectors
Monday, August 10th, 2009 AT 8:41 PM
4FATHER6
We have cheched the codes there are no codes coming up. It was told to me that sometimes the computer needs to be changed after the transmission has been worked on to reset the computer is this true?
Tuesday, August 11th, 2009 AT 8:13 AM
BMRFIXIT
  • 19,053 POSTS
Never heard of it and or happen with us at all so far
is it the tranny shop that saying that to you
Tuesday, August 11th, 2009 AT 6:48 PM
