1992 Ford Taurus window fogs up
MEGRYAN123
Heater problem
1992 Ford Taurus 6 cyl All Wheel Drive Automatic
After the car warms up while driving the windshield fogs up so bad and you can smell antifreeze coming out of the vents.
Nov 9, 2008 at 3:23 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Your heater core seems to be faulty. The foggy film on the windshield that you speak of is the coolant coming through the vents. The heater core is usually a cheap part. The labor is very expensive though. Costs range from $200 to $500 depending on location and vehicle. If you feel like you can tackle this on by yourself, I can give you some instructions on doing so.
Hope this helped. Thanks for using 2Carpros.com!
Nov 9, 2008 at 3:39 PM
