1992 Ford Taurus Replace Water Pump
1992 FORD TAURUS
120,000 MILES • 6 CYL • FWD • AUTOMATIC
HUBEXTERMAN
Would like to know the steps to replacing water pump in 1992 Ford Taurus
Donating my time to help my neighbor who is out of work.
It's growling pretty bad, but not leaking yet!
Thanks for any help you can give.[img:ab0c0c990a]http://www.2carpros.com/forum/automotive_pictures/541053_Waterpump1_1.jpg[/img:ab0c0c990a]
Jun 19, 2010 at 7:16 PM
BMRFIXIT
  • CERTIFIED EXPERT
  • 19,053 POSTS
Drain cooling system.
Remove accessory belts.
Remove idler bracket from engine.
Disconnect heater hose at water pump.
Remove water pump pulley bolts.
Pulley will remain loose on hub due to insufficient clearance.
Remove 11 water pump mounting bolts
Jun 19, 2010 at 8:26 PM
