1992 Ford Taurus relay flasher
JENN1098
  • 1992 FORD TAURUS
Electrical problem
1992 Ford Taurus 6 cyl Front Wheel Drive 85000 miles
I bought a relay flasher and I cant figure out where it goes. I looked under my steering column and beside my fuse box. No luck. Can you please help me?
Tuesday, January 15th, 2008 AT 4:33 PM
TAURUSWHEEL
  • 718 POSTS
I believe, not 100%, that it's located on a small panel, along with a couple other pieces, behind the lower trim panel, under the steering column. Four torx screws to remove the panel, may be up above the gas pedal on a support bracket. I believe the wiper motor governor may also be located there.
Tuesday, January 15th, 2008 AT 5:54 PM
