1992 Ford Taurus rear windows
LANCEMAN138
Electrical problem
1992 Ford Taurus 6 cyl Front Wheel Drive Automatic 107k miles
I have automatic windows. My front windows work perfect. But my back windows wont roll down(back buttons dont work, nor the driver's window controls) I don't believe its the motors for them, because there has only been one owner, and the back seat was never used. they had no kids, and the back seat is almost new looking. So I don't think its wear and tear on the window motors. Any pointers or suggestions would be extremely appreciated. Thanks
Lance S. Horn
Sep 25, 2009 at 1:41 AM
RACEFAN966
  • 5,029 POSTS
Well looking over the wiring diagram I can find only one of two things if it isn't the motors. They are the master switch on the drivers door or the switches on the rear doors. I would more so suspect the master switch as this is what sends the power to the rear switches.
Sep 25, 2009 at 2:41 AM
LANCEMAN138
so basically your saying the switches themselves? Should I pull the master switches first and examine them? Am I looking for shorts, or replacement of the switches themselves? If you could maybe just let me know what to look for I would again very much appreciate it.
Thanks
Lance S. Horn
Sep 25, 2009 at 2:51 AM
RACEFAN966
  • 5,029 POSTS
The power window circuit is very basic really. So what I would do is pull the drivers side switch (master switch) and with a test light check the blue wire with the black stripe should have power (this is power in). Then check the red wire with the light blue stripe, this goes to the left rear window. So what you do here is hook up a test light and push the up should get power, if no power bad switch. If you have power there then check the yellow wire with the blue stripe (this is the down to the left rear window). So you hook up you test light to that wire and then push the down to that window if now power bad switch. You do this with the harness pluged in you are testing to see if power is going through the switch. You also have to do this with the key in acc. possition or key on engine off which ever way makes the front window work. Let me know what you find and we will take it from there.
Sep 25, 2009 at 3:01 AM
