1992 Ford Taurus radiator fan relay
EHOFFMAN1
Electrical problem
1992 Ford Taurus 6 cyl Front Wheel Drive Automatic
cant seem to locate fan relay.
cooling fan does not come on
when i direct wired the fan it works
i am assuming this means the relay is bad
Jul 11, 2009 at 1:48 AM
JGAROFALO
  • 489 POSTS
[quote:3f506fbb94="ehoffman1"]Electrical problem
i am assuming this means the relay is bad[/quote:3f506fbb94]
The fan relay is located in the CCM module that is attached to the top of the radiator support. Also, don't overlook the coolant temperature sensor on the engine. Better to spend some time diagnosing than to just start throwing expensive parts at the problem.
Jul 14, 2009 at 10:00 AM
EHOFFMAN1
Okay, I switched out fan relay, problem fixed. I ran the car, after only about 2 minutes it made a loud clonking noise, I tuned it off... looked under hood, anti free comming out of lower front right of engine, blown head gasket ?
Jul 14, 2009 at 10:05 AM
