1992 Ford Taurus Radiadtor
TTWNA
  • 10 POSTS
Engine Mechanical problem
1992 Ford Taurus 6 cyl Automatic
Ijust bought this car and there is a work order from pep boys saying the radiator was flushed but the water is a rust color
May 28, 2008 at 4:35 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation.
It sound like that the radiator may ave been back flushed only. To do a full flush the thermostat will have to be removed and the block & heater core flushed independently until they run clean. The radiator should be removed & flushed and flow tested as well. Fresh coolant should be used & the thermostat replaced to make a good job of it.
Mark (mhpautos)
May 28, 2008 at 10:18 PM
