1992 Ford Taurus drain valve for cooling system
SAM32979
Engine problem
1992 Ford Taurus V6 Two Wheel Drive Automatic 70,000 miles
My cooling system needs to be drained and replaced and I am having a hard time locating the drain valve on the radiator, can you give me a description of where to look?
Dec 8, 2007 at 12:33 AM
MERLIN2021
  • 17,250 POSTS
If the car has the splash shield under the engine, remove it, then you will be able to access the draincock at the bottom of your radiator....
Dec 8, 2007 at 12:51 AM
  • 55,858 POSTS
The radiator drain valve is on the left side of the radiator in the tank near the bottom. Here is the location in the images below. Check out the images (below). Let us know if you need anything else.
Jul 20, 2024 at 6:15 AM
