1992 Ford Taurus Brake Lights & turn signals
1992 FORD TAURUS
NELLERS
Brakes problem
1992 Ford Taurus 6 cyl Two Wheel Drive Automatic
I need to know what to do about my signal lights, brake lights and header lights-None of them will work-the fuse that goes to all of them is good and not broken-so what would be the problem in trying to track down the problem-i mean what do I do to find out whats wromg?
Jun 29, 2010 at 8:53 AM
BMRFIXIT
  • 19,053 POSTS
All go thro the combination switch
if all tested OK suspect and check the multifunction switch (combination switch )
Jun 29, 2010 at 9:58 AM
