1991 Ford Taurus with 48,000 miles
CHRISTINE_EAGAN
Is this make/model car known for having transmission problems?
Mar 16, 2006 at 3:47 AM
PARKSIE
  • 11 POSTS
[quote:0277e6e484="christine_eagan"]Is this make/model car known for having transmission problems?[/quote:0277e6e484]
Yep, it surely is. I owned a 1990 Taurus til a year ago and got pretty well-read on the transmission issue.
Up until 1990, the Taurus had a mechanically shifted transmission, meaning that the shifting was activated by a cable running from the throttle. In 1991, a new electronically controlled transmission was introduced (known as the AXODe), and my understanding is that it was a real lemon. The telltale sign was a rough or hesitant shift out of first gear. Part of the problem (again as I understand it) was a part called the clutch piston, which in the 1991 and newer transmissions had a tendancy to crack or otherwise fail.
Best of luck with your vehicle.
Mar 26, 2006 at 2:36 PM
