1991 Ford Taurus WINDOW PROBLEM
SALOUCKS
1991 Ford Taurus Front Wheel Drive Automatic 12000 miles
We removed the old radio and were set to install a new one, but since we were sold the wrong parts the radio was not installed. New speakers were installed in the front as well as in the rear with no problem.
The problem now is that the windows will not work. They are electric, we have checked the fuse and it is good, all wires look to be intact but we still have not power to the windows.
Can you help?
Angie
Mar 14, 2010 at 6:24 AM
BMRFIXIT
  • 19,053 POSTS
Remove driver door master switch and check lt BLU/BLK wire for power
check door jam wiring harness
check window relay (behind left side of I/P above fuse panel)
Mar 14, 2010 at 11:57 AM
