1991 Ford Taurus Engine Revs
MOBERMAN6
Engine Mechanical problem
1991 Ford Taurus 6 cyl Front Wheel Drive Automatic 200k miles
When the car is started or running the engine revs will not stop reving... I can push the gas to increase the RPM'S more than what it is already reving
Oct 24, 2009 at 8:34 AM
OBXAUTOMEDIC
  • 3,719 POSTS
Is engine light on? If so will need to pull codes...
If not then will need to look for a Vacuum Leak.
Check all hoses for crack, breaks, etc.
Mark S
Oct 24, 2009 at 8:46 AM
