1991 Ford Taurus Battery light?
JAYMAN1566
Electrical problem
1991 Ford Taurus 6 cyl Front Wheel Drive Automatic
i've got a battery light on, i've cleaned and wire brushed the connections, wire brushed the battery terminals, and the light is still on. i have a steady 11.7 volts and was wondering what the voltage should be? (when running) i tried the old method of disconnecting the battery when the car is running and it stopped. just want to be sure the alternator is going bad before proceeding....Please help! Thanks!
Mar 16, 2010 at 6:52 AM
DOCFIXIT
  • 18,828 POSTS
Alt is faulty battery voltage engine offf 12.6v or higher.
Alt output voltage engine running 14.5 to 15.5V
Mar 16, 2010 at 7:33 AM
