1991 Ford Taurus 1991 Ford Taurus Sho No Spark
140,000 MILES • 6 CYL • FWD • MANUAL
MNDUKE
Hi. I own a 1991 Ford Taurus Sho. Yesterday my decided to help me tossed a battery into my car. I thought it was the same battery I had been using and turns out it was not and the terminals were opposite and the cables were put on backwards. There was a lot of sparking and part of the wire from a fusible link blew out around where it connects to the starter solenoid. Afterwards the car wouldn't turn over and kept blowing the number 8 fuse. I replaced the blown part of the fusible link and the starter solenoid. The car will turn over but will not start. It's currently not getting any spark. All other systems are fully functional. Any ideas or help to what may be the cause would be greatly appreciated. Thanks.
Nov 7, 2009 at 8:54 AM
  • 75,988 POSTS
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Nov 7, 2009 at 9:01 AM
