I just purchased this car for my daughter and didn't notice that the tachometer wasn't working because the needle is below the pin (I shift by sound). It does appear to be trying to work, since it drops down when you turn the car off, and just holds hard against the pin while the car is on. The owner said that he had to be jump started a couple of times due to a bad battery, and I saw another entry on another site for a 91 that had this same problem due to being jump started, but he didn't get an answer. Is there any easy way to get the needle back around so it is on top of the pin again?
Aug 3, 2008 at 2:41 PM
