1990 Ford Taurus Retro fit
58,000 MILES • 6 CYL • FWD • AUTOMATIC
LADDER16
I just put a retro fit kit on my son's vehicle and the tested the compressor and it works, the clutch kicks in and the line holds a charge. Filled it from the low pressure side like the kit advised but the air is still hot blowwing out. What am I doing wrong
Aug 5, 2008 at 10:05 AM
BMRFIXIT
  • 19,053 POSTS
I would change the orifice tube
evacuate the system
and then fill it
or make sure u have enough 134A in the system
check if lines getting cold and if so check blend door
Aug 5, 2008 at 2:50 PM
