Wanna fill in the blanks? What is the problem? factory radio?
Jun 30, 2008 at 2:03 AM
SUE4084
MEMBER
yes, factory radio. very faint humming alm
ost. fuses good, no lights, nothing. thx
Jun 30, 2008 at 5:35 AM
MERLIN2021
✓Experienced Mechanic
About the only thing you can check is the plugs and fuse, to remove the radio, there is a tool its two u shaped handles that go into the four holes in the dash, then pull the radio out and check th plugs and the ground.
