Wanna fill in the blanks? What is the problem? Factory radio?
SPONSORED LINKS
Monday, June 30th, 2008 AT 9:03 AM
SUE4084
MEMBER
Yes, factory radio. Very faint humming alm
ost. Fuses good, no lights, nothing. Thx
Monday, June 30th, 2008 AT 12:35 PM
MERLIN2021
MECHANIC
About the only thing you can check is the plugs and fuse, to remove the radio, there is a tool its two u shaped handles that go into the four holes in the dash, then pull the radio out and check th plugs and the ground.
