1990 Ford Taurus Pinging and other problems
120,197 MILES • 6 CYL • FWD • AUTOMATIC
IBDARTS
I have a 1990 3.0 v6 taurus. I had the cigarette lighter short my car out about a year ago. I drove the car when the short was bad. It would kill the battery every night. I changed the voltage regulator twice before i figured out tht the short was the lighter.
The car has run bad ever since. I did a full tune up a week later and it didn't help. I get a few pops from the engine when its cold and i accelerate. Doesn't do it when its warm tho. It will ping going up hills when it is cold or warm, it got better after running some fuel cleaner in it. When i put the car in park it will run for a few seconds and then die. It will sometimes die at a stoplight as well. The check engine light has never come on.
It ran perfect before this short. I passed emesions with some of the lowest scores tht i have seen. It passed emissions after the short tho but it took 2 times going thu and the scores were really high.
I'm wondering if there is something tht i can replace or if the short hurt a bunch of things?
Please help.
Thx Tom
Jun 26, 2009 at 11:44 AM
JGAROFALO
  • 489 POSTS
[quote:864063fc40="IBdarts"]Engine Performance problem
1990 Ford Taurus 6 cyl Front Wheel Drive Automatic 120197 miles
Please help.
Thx Tom[/quote:864063fc40]
I don't see a relationship between the lighter problem and the engine problem. Possible but not likely. This sounds like a problem with the ignition module, PIP sensor, or distributor.
Start by checking the timing with a good timing light. Be sure to remove the SPOUT connector first. The mark should line up, and be steady at 10 degrees BTDC.
Jun 27, 2009 at 12:40 AM
