1990 Ford Taurus Car no pick up, need high rpm.
300,000 MILES • 4 CYL • FWD • MANUAL
AMIROX
My Car no pick up after changing gear.
1. It is cause by gear box problem?
2. Clutch near to wear off?
3. Cable plug?
4. Plug wear off?
5. Drive shaft?
6. Air filter dirty?
Please help me.
Apr 2, 2009 at 5:01 AM
JGAROFALO
  • 489 POSTS
There are a host of problems that can cause what you describe. Some things to check:
Fuel filter.
Fuel pressure (weak pump maybe?)
Air filter.
Exhaust restriction.
Low engine compression.
Any of these things can cause a loss of power. Keep in mind that with 300,000 miles, it is possible that the engine has simply gotten too worn and tired to keep up with the big dogs.
Apr 2, 2009 at 10:34 AM
