1990 Ford Taurus brake lights
13,700 MILES • 6 CYL • FWD • AUTOMATIC
WKMAY1
I am having problems with my brake lights staying on al the time . I have changed the brake switch light and the multifunction switch, fuse and looked for shorts in the wiring could you please help,Bill
May 31, 2008 at 3:54 AM
BLACKOP555
  • 10,386 POSTS
make sure the switch was adjusted properly, should be a closed circuit, switch in when teh pedal is released, when the pedal is depreseed the circuit should be open, switch out.
May 31, 2008 at 8:54 AM
