HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Taurus
Engine
Symptoms
Idle Rough
1990 Ford Taurus 1990 Ford Sho Runs but has Rough Idle
HALOJUNKIE222
MEMBER
1990 FORD TAURUS
6 CYL
FWD
MANUAL
224,000 MILES
The 1990 Ford Sho i'm looking to buy from a guy runs fine, but has a real rough idle, if any at all. Any suggestions?
Sunday, January 13th, 2008 AT 11:02 PM
BLACKOP555
MECHANIC
First clean out the throttle body and replace the IAC module, you may also opt to clean the egr and replace the PCV valve.
SPONSORED LINKS
Monday, January 14th, 2008 AT 7:12 AM
Please
login
or
register
to post a reply.
Related Engine Idle Rough Content
Rough Idle At Start Up
Causes Of Rough Idling During Cold Starts. After Warning Up, Idle Smooths Out. Possibly Some Loss Of Power While Driving. Seems As If Not...
Asked by
Ray Herbert
1 IMAGE
2001
FORD TAURUS
GUIDE
Rough Engine Idle
A rough engine idle condition is a common issue that many drivers face often indicating underlying problems within the engine, fuel or ignition system. We have created this...
Rough Idle
I Have A 2005 Taurus Sel With 123k Miles. The Engine Runs A Little Rough At Idle And The Tach Jumps Up And Down About 50 Rpm When The Car Is...
Asked by
Topcat1961
2005
FORD TAURUS
Rough Idle
Have A 1997 Ford Taurus Sho I Was Wondering What Could Be Causing A Rough Idle, I Have Changed Plugs Did Visual Inspection Of Coil Packs So...
Asked by
kevinloken
1997
FORD TAURUS
1997 Ford Taurus Rough Idle
Hello, I Have A 1997 V-6 Ford Taurus That Idle Really Rough 95% Of The Time. Other Than Idle The Car Runs Fine. I Have Replaced The Spark...
Asked by
fjbarboza83
1 ANSWER
1997
FORD TAURUS
1995 Ford Taurus Frequent Shifting And Rough Idle
At About 35-40 Miles Per Hour My Car Will Shift Frequently Back And Forth Between Gears. This Especially Happens When Going At Slight...
Asked by
eiderman
1 ANSWER
1995
FORD TAURUS
VIEW MORE
SPONSORED LINKS
Vacuum Leak Symptoms
Vacuum Leak Test and Repair
Vacuum Leak
Online car repair manuals
