1990 Ford Taurus 6 cyl
I am working on a 1990 ford tarsus the motor turns over but will not start. I pulled the spark plug out to see if it was giving a spark and it was not. I replaced the coil and still no spark I checked the wires going to the distributor and i have battery voltage on terminal 2 this is the run position terminal on terminal 3 the run circuit no voltage and no voltage on terminal 4 the start circuit. I have a Hanes book but I don’t know what to check next
Mar 7, 2009 at 10:21 AM
