1989 Ford Taurus Transaxle spider gears
SILVERXUAN
Transmission problem
1989 Ford Taurus 6 cyl Front Wheel Drive Automatic
How do you inspect or change out the transaxle spider gears?
May 17, 2009 at 3:12 PM
2CARPRO JACK
  • 11,533 POSTS
Do you have any training in automatic transmissions? If not, I wouldnt go there.It requires special tools to disassemble the trans, not to mention you will need to remove the trans from the car which requires taking the entire front cradle (frame) out of the car, leaving the engine hanging from a special mount designed for this.
May 18, 2009 at 12:59 AM
