1989 Ford Taurus Rotor inside the distributor
CRISSY1106
Electrical problem
1989 Ford Taurus 6 cyl
I took off the distributor cap so that I could replace the pick-up assembly but I couldnt get the rotor off. So how do I get the rotor off so that I can replace the assembly?
Jun 30, 2010 at 7:17 PM
BMRFIXIT
  • 19,053 POSTS
Rotor should pull off
rust maybe holding it down
replacing the pick up coil require removing the distributor and disassemble
need a pulley to do so
good luck
Jun 30, 2010 at 11:04 PM
