1989 Ford Taurus No lights, tail lights
1989 FORD TAURUS
60,000 MILES • 6 CYL • FWD • AUTOMATIC
LYSETTE
All of the lights will work, radio won't, anything electrical. Not burned. Changed bulbs.
Also where is the thermostat for the radiator at?
Thank you so much for your time.
Lysette
Oct 31, 2009 at 3:03 PM
BMRFIXIT
  • 19,053 POSTS
Check fuses
turn car on and turn lights on , use a test light or volt meter check fuses
thermostat :
follow the upper radiator to the engine and thermostat housing
Oct 31, 2009 at 3:48 PM
