1989 Ford Taurus exhaust manifold
1989 FORD TAURUS
UNLIKELY
Engine Mechanical problem
1989 Ford Taurus 6 cyl Front Wheel Drive Automatic
the exhaust manifold closest to the firewall turns glowing red
Sep 23, 2010 at 5:46 PM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
I would first be checking for a blocked of failed cat converter, start here.
mark (mhpautos)
Sep 23, 2010 at 9:23 PM
Hi unlikely, Welcome to 2carpros and TY for the donation
Its getting too much fuel-check injectors and fuel pressure regulator if its leaking-could be running in the open loop mode all the time not switching due to the coolant temperature sensor and oxygen sensor
Also go this link: https://www.2carpros.com/forum/exhaust-manifold-turning-red-vt14824.html
Sep 23, 2010 at 9:29 PM
