1989 Ford Taurus clutch replacement
85,678 MILES • 6 CYL • FWD • AUTOMATIC
EDDIEMAC56
My air conditioner is working however the clutch is not engaging fully. You can see it pull in but appears to be slipping. The compressor was replaced four years ago by the dealer. Can you just replace the clutch or do you have to replace the compressor and clucth as one assembly?
Apr 23, 2008 at 6:59 AM
  • 31,937 POSTS
Hi there,
I believe that the clutch assembly is a serviced item and you should be able to just do that.
Mark (mhpautos)
Apr 23, 2008 at 11:05 PM
