1989 Ford Taurus Car wont start
158,000 MILES • 6 CYL • FWD • MANUAL
THATGUY1011E
its a 89 ford taurus sho manual 3.0l .the car wont start suddenly. i tried starting it and heard a click . i replaced the starter and relay.same symthoms.everything else works lights radio wipers etc. car is not able to be jumped .
Mar 26, 2010 at 7:56 AM
  • 75,988 POSTS
Double check the battery condition and connections if okay check and test the clutch switch and ignition switch.
Mar 26, 2010 at 9:12 AM
THATGUY1011E
[quote:5ee7629a79="rasmataz"]Double check the battery condition and connections if okay check and test the clutch switch and ignition switch.[/quote:5ee7629a79]
i double checked connections and battery i also changed the cable terminals. this time when i tried to start the car the negative terminal ground melted as well as the the ground from the firewall to the manifold.
Mar 26, 2010 at 11:04 AM
  • 75,988 POSTS
You have a power source that's direct short to ground. You sure the battery is hooked-up correctly.
Mar 26, 2010 at 11:11 AM
THATGUY1011E
[quote:1ee41c199e="rasmataz"]You have a power source that's direct short to ground. You sure the battery is hooked-up correctly.[/quote:1ee41c199e]
not to sound stupid but what do you mean by direct short to ground. and yes i replaced everything back in the position i found it. a hanger seemed to have fallen out of the engine bay not positive on that though around the time it stoped.
Mar 26, 2010 at 11:53 AM
  • 75,988 POSTS
Check at the alternator if that hanger is shorting out the battery terminal on it
A 3.0 SHO or 3.8 engine starting system has no clutch switch this is suppose to be part of the starting system-You sure its a manual tranny-Now if its automatic check the starter relay. Terminal melting is due to excessive heat caused by a short-Double check the positive cable all the way to the starter.
Mar 26, 2010 at 12:22 PM
THATGUY1011E
[quote:fc103cc2e9="rasmataz"]Check at the alternator if that hanger is shorting out the battery terminal on it
A 3.0 SHO or 3.8 engine starting system has no clutch switch this is suppose to be part of the starting system-You sure its a manual tranny-Now if its automatic check the starter relay. Terminal melting is due to excessive heat caused by a short-Double check the positive cable all the way to the starter.[/quote:fc103cc2e9]
im not sure. i never saw the hanger before and i dont know where it may have been.its not in there anymore. thanks for the help. ill check the starter cable again. it its a manual 3.0 sho
Mar 26, 2010 at 12:31 PM
