1988 Ford Taurus
10,000 MILES • 6 CYL • 2WD • AUTOMATIC
SARA_B994
Recently I have noticed I can drive my car about a mile and the oil light comes on about 2-3 minutes after it will start making a strong ticking noise ( not a knocking) When I pull over, Leaving the car run it smokes from the bottom of the motor. I don't have much power behind the pedal once this all happens.
My fiance changed the oil after using an engine flush and there are small (size of a ink pen tip) peices of metal. He then drove the car after putting oil back in the car and it s still doing it.
Mar 8, 2009 at 6:22 AM
DAVE H
  • 13,383 POSTS
sounds like the oil pump may be faulty ..also pen tip size pieces of metal in the oil is not a good sign ? have the pump and crankshaft etc. inspected !!
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_81.png
Mar 8, 2009 at 7:02 AM
