1987 Ford Taurus solenoid wiring
177,645 MILES • 6 CYL • AWD • AUTOMATIC
SHERIR39
I used to be able to start the car by wiggling the wires now it wont start at all,I replaced the solenoid and still have the same problem.I have to touch the bolts together with a screw driver to get it to start.
Mar 17, 2009 at 9:12 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:15c4d70099="sherir39"]Electrical problem
1987 Ford Taurus 6 cyl All Wheel Drive Automatic 177645 miles
I used to be able to start the car by wiggling the wires now it wont start at all,I replaced the solenoid and still have the same problem.I have to touch the bolts together with a screw driver to get it to start.[/quote:15c4d70099]
Which wire did you wiggle? if it was the smaller one then you may have broken the wires inside the casing and you will need to fix it.
Mar 17, 2009 at 9:22 AM
SHERIR39
We wiggled the wire that hooked to the top bolt it was blue with red lines..now you have to take a screw driver and touch both bolts to get it to start.We already replaced the sloenoid
Mar 17, 2009 at 11:51 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:5f8c71d5e4="sherir39"]We wiggled the wire that hooked to the top bolt it was blue with red lines..now you have to take a screw driver and touch both bolts to get it to start.We already replaced the sloenoid[/quote:5f8c71d5e4]
Ok, you will need to test that wire for power. You will need a Test Light. To check for power clip the one end of the test light to a good ground. Then touch the other end to the wire and have someone try starting the car. The light should be nice and bright while cranking engine. If not using the sharp point on the test light pierce the wire about an 1" or 2" back and crank engine if light lights then wire will need to be repaired.
Mar 19, 2009 at 12:34 AM
